GT
Hi
I am experiencing fule starvation at over 5000 prm in top gear. It pulls cleanly thruogh all the gears to the red line and in top just fine, then after about half a mile the bike just loses power as if it has run out of fuel (it hasn't). If I throyttle back to about 4500 it rides happily and after a few seconds yuo can pull cleanly above 5000 again and then after another 10 seconds or so the same thing happens. It only really impacts in top gear as that is when the trottle is wide open, you can attain and hold 7000 / 8000 in any other gear, I think because the trottle is open much less as the gearing is higher.
The bike has ben fully rebuilt, runs and idels fine. Plug colour is perfect - light biscuit. Standard exhaust ( stainless with Cox chrome silencers). Standard carburation, but I do not know what size main jets are in it - drilled out air holes in fuel cap a little to ensure clear air passage.
It does it on a full or low fuel level and on main and reserve tap position. Cavis Benz fuel pipes fitted. Standard airbbox, no filter.
any ideas?
regards
Glenn
any ideas?
regards
Glenn
