Smartv11
- Meopham, Kent
Bought a pair of fork gaiters, which don't have vent holes. I wonder should I make some holes, or is not really going to be an issue?
Smartv11 said:Bought a pair of fork gaiters, which don't have vent holes. I wonder should I make some holes, or is not really going to be an issue?
mauricejota7604 said:The gaiter rubbers have a couple of tiny vent holes about 2mm in diameter
Dellortoman said:If you're talking about dynamic venting as the forks pump up and down, air is a viscous fluid and the volume inside the gaiter will change too rapidly for the tiny vent holes to do much venting at all. you'd need a bloody big hole for that - too big for any practicality I suspect. By that I mean if you cut big holes in them you're kind of defeating the purpose of the gaiters in the first place. So what's the purpose of the wee holes?
Albert Einstein came up with his theories by doing what he called "thought experiments", just thinking about how things work and what must be happening. So I've been doing a thought experiment about a gaiter on a working fork leg:
The little bleed hole won't allow sufficient air through to vent the gaiter fully under the rapid compression of the fork leg as the front wheel hits a bump at speed. But the gaiter will expel air on compression easily enough because it will expand slightly with the internal air pressure and blow the air past the seal on the fork slider or at the top fitting. So there's minimal risk of it bursting due to internal air pressure. Thinking about this, it might be a bad idea to fit gaiters with jubilee clips (at both ends) to hold them in place.
As the forks extend again, the pressure inside the gaiter will decrease, which will hermetically seal the lips of the gaiter against the fork slider and top fitting. So the air expelled on compression won't be sucked back in on extension. The sides of the bellows will collapse in a bit and may rub against the fork leg, but that's no big deal. The net result will be that the bellows will (on average) run with lower than atmospheric air pressure. As soon as you stop the bike and get off, the elasticity of the deflated rubber gaiter bellows will suck air back in through the little bleed hole. So the gaiter will have returned to its normal shape before you've had time to notice anything different.
sfcpiet said:Cam,
That may well be correct, in theory.
In practice, the 2mm vent holes work fine, with no deformation during deflection over bumps...
