Dellortoman
- Tasmania, Australia
For those of a pedantic disposition ...
I've been peering at the innards of my Jota's gearbox. More out of OCD behaviour than anything else. I counted the teeth on each gear and worked out the ratios, but my 1st gear ratio didn't tally with Ian Falloon's Laverda bible. So I went and counted the teeth again. It turns out that Falloon is wrong (shock horror!).
If you have a copy of Falloon's book, you may want to amend the Laverda 1000 specs on page 152. The correct gear ratio is 1:2.857
Actually Falloon is more than just wrong, he's very wrong. He actually says 1:2618 (although I assume he means 1:2.618) which would be very low geared indeed. At 5000 rpm it would take a bit over two minutes to get one revolution of the back wheel!
I thought there may have been an earlier or later version, or a close ratio box that had 2.618 as a first gear, but there is no possible combination of tooth numbers that would give that ratio with a 21/30 sleeve gear. So I dunno where he got it from.
Cape, you might want to amend your gear ratio calculation spreadsheet on your website as you have used Falloon's number. http://www.laverdafinland.org/gear_ratios.htm
If you don't believe me, JLO has it correct on his website http://www.laverdamania.net/chart.htm
For anyone who is interested in tooth numbers for a series 1 1000, here they are:
1st 34/17*30/21 = 2.857
2nd 29/22*30/21 = 1.883
3rd 25/26*30/21 = 1.374
4th 23/28*30/21 = 1.173
5th (direct drive) = 1
Note that the first four gears drive via the layshaft and the sleeve gear. So the sleeve gear ratio of 30/21 is common to all of them.
5th gear is direct drive via dogs straight through from the clutch to the output shaft.
In neutral, drive to the layshaft is disengaged.
Cam
Cam
