Vince said:Buggar thought the manufacturer might have gone there to reduce stiction.
sfcpiet said:Vince,
The slider itself doesn't have any contact with the stanchion, it moves on the split bushes. Or do you have one of the rare versions without bushes? Nevr seen internal anodising on any Marzocchi product...
Vince said:Just a thought bubble, if it was hard anodised outside then maybe internal as well. I am looking at doing the usual Maz 38mm on my Pantah internally and I have no idea if it can be restricted to internal only, or even how thick it is.
breganzane said:It can be masked but as I understand it can be tricky, it's an immersion process somewhat like plating. Hard anodising is a little different to decorative anodising, but either process will likely benefit... it converts part of the surface into a hard layer, more or less by corrosion.
