L
Legs
Guest
Ha Ha. I recently replaced the bicycle speedo on the Yellow Peril; mounted the pick-up the same way as the previous one, that is, in line with the magnets's rotation. Wondered why the bike suddenly doubled it's speed. Turns out that the new pick-up had to be mounted at 90 degrees to the magnet's rotation.
Would changing the calipers from behind the stanchions to in front, or vice versa also require mounting the speedo drive on the other side, and if so , won't the speedo run backwards :
Great if you are selling the bike and want to reduce the mileage
