handlebar fixings 1200/non return forks help
  • Start date Start date
more than likely!I compressed them on the ground and each fork returns well now. :D
Dosen't mean they are not bent, simple test is to grip the fork slider in a vice and rotate the stanchion, any bend even very slight can be easily seen at the top as you are rotating it.
    Keith
OK technique  worked a treat Clem,springs not broken, ,going to test for any bends Keith, at a friends at the weekend.
Shaun
Keith ,took it to friends and one fork is out by+.065mm on gauge, and you can clearly see it as it rotates ,as you say.Off to another friends press now.However could do with another as it does have some pitting where the fairing has rubbed over the years.(out of travel area)
Thanks all Shaun
lemonjelly said:
Keith ,took it to friends and one fork is out by 0.065mm on gauge, and you can clearly see it as it rotate as you say.Off to another friends press now.However could do with another as it does have some pitting where the fairing has rubbed over the years.(out of travel area)
Thanks all Shaun
0,065 mm?
Forget it.
