See my headlamp bowl has a forked, hooked type appendage. What bit am I missing for attaching the rim to the bowl. What part do I ask for...if you can still get it?
As I thought.
The bit attached to the outside edge of the shell is not needed.
You are missing a clip/screw assembly that attaches to the hole in the rim and then clips/screws into place once the rim is mounted on the shell.
Wolfgang sells the parts you need.
