Headlight supports 3C with 38 Ceriani - whats wrong here?
  • Thread starter Thread starter 3C_Stefan
  • Start date Start date
Hi Stefan,
Normally, the alloy nut that is being clamped by the upper triple clamp should be tall enough for the clamp to slide up- and downwards, so that you can find the correct height. Looks like the one on your bike is too short to do this..
Marnix
Stefan,
Looks OK to me.  Don't be fooled by the gap, no washer needed.  The centre nut tightens up against the bearing and provides a clamping cylinder for the top yoke.  Clamp it wherever it ends up.
The profiled rubber rings need a profiled aluminium ring to go with them, several different thickness rubber rings were used, depending on frame/fork set up.  Actually, only the 1000 and 750GTL used these brackets, but the GTL tubes are for 35mm forks so won't fit later triples anyway.  When installed, the rubber ring should only slightly be compressed, the tube being clamped between top and bottom yoke.
HTH,
Here is a Pic of mine there is a spacer between the top nut and lower nut
for full size image see
https://picasaweb.google.com/lh/photo/FoXmeA3Y-QS-CqGJqgI4L1tvCdBhu5LM9k3lO_MXbHw?feat=directlink
