macavity99
- Bedfordshire, UK
Got the engine pivoted down, still attached by two rear bolt. Refitted barrel and cylinder head today.
Nothing lines up with the camchain. I've got ends of chain in my hands but the the crankshaft TDC mark is nowhere near where it should be. How can I move the chain on the crankshaft sprocket to get everything lined up?
The green book says on page 60: "The cylinder must be truly vertical for the cam chain to be free of the lower sprocket".
Does this mean that I must remove engine from frame completely to finish reassembly? Or is there a way around the problem?
Thanks
Steve in UK
Thanks
Steve in UK
