I'm currently fitting new cush rubbers to 8 of Zane clutch baskets. The old pressed rivets have come out, leaving a 6.17mm hole in the lugs.
Us Aussies must be stupid. I can buy a 7*1mm tap, but I can't buy 7*1mm bolts. Go figure. We can only count 2 fingers at a time. 6, 8, 10, 12. (Is this because we are so good that we have spent too long giving the rest of the world the forks?) Much unlike you lads in Europe and Japan that can count rationally. 6,7,8,9,10,11,12.....
What I am looking for is about 100 bolts, 7*20*1, grade about 8.8 (maybe less), with a total head depth of, ideally, 3mm. And "safety serrated washers" to suit. If I have to skim the heads I will. I've only got 4.63mm clearance behind the clutch basket
I was given a sample by our local guru, which are too thick in the bolt head area, but if needs be, I can skim the heads of in the lathe.
If someone has a source and can buy for me, I'll send $.
Regards, Greg
Regards, Greg
