Hey all,
First of all I want to send a "thank you" to all that took the time to reply on my post - It has been greatly appreciated.
I took all of the advice into consideration and decided that a more thorough investigation was needed. And boy I was glad that I did.
The following was found.
? Found a defective accelerator valve in one of the carbs.
? Gaskets in general were worn on all 3 carbs.
? Choke pistons was worn on all 3 carbs (rubber innards)
? O-rings on intake manifolds was worn out ? all 6 of them!
? The original pickup bush on the crank was loose!
? Rubbers form carbs to air box was mounted the wrong way, making room for air intake on carbside of rubber.
? Camchain was worn
The following was mended/done.
? I took the carbs apart and cleaned every bit of them. Bought new of almost everything including gasket kits, choke pistons, accelerator valve, needle, jets and all.
? Bought new O-rings for the intake manifolds
? Bought new shims and readjusted all the valve cleareances.
? Bought new camchain and fitted it.
? Bought a Moto Witt DMC2 ignition.
? Did a new compression test ? this time with throttle @ wide open and got results at around 120 PSI on all 3 cylinders (I believe its somewhere in the middle = semi worn barrels)
? Stripped the air box innards
It now runs with following specs.
? 256AB needle jet
? K1 needle
? 65 pilot jets
? 135 main jets
? DMC2 ignition with a 36 degree advance curve (setting 6).
Did my first test run on it last night and what a difference! There?s no more ?holes? in the acceleration ? it runs clean and pulls even on acceleration. I did have problems getting it to idle correctly but assumes that I need to adjust the carbs a bit more.
The plugs seems on the lean side though ? did only 15 km. so need to go for a longer ride to be certain.
I'll post an update as soon as I get the little things sorted
Best regarts,
Martin
