Hi JB
I have had quick and helpful responses directly from the three fellows at Ignitech, in English. You might consider emailing them directly, they seem very helpful.
I am also curious about the use of stock Laverda/Bosch pickups with an Ignitech box and will be watching for whatever the answer is. Sorry, I don't know the answer myself. I also wonder how accurately the three individual pickups on the stock 120 plate can be set in relation to each other to trigger exactly 120 degrees apart, I have always struggled with them, or even just the two stock pickups on a 180. I wonder if the Ignitech software could compensate for the three ignition pickups if they are not exactly 120 degrees apart?
The system RedAx has developed and sells use a custom made Hall Effect trigger board and adjustable crank end two piece trigger rotor with an Ignitech box. The Hall Effect trigger board that RedAx supplies has LED indicator lights that makes it easy and straightforward to set initial base timing. I do not know if he has developed a trigger plate and system for a 120 yet?
Paul LeClair
