As part of my 3CL restoration I completely stripped my 38mm Ceriani forks. First surprise came as I tried to remove the damper piston/rods -- one side came out reasonably easily and the other needed "significant" help with a pipe hammered in from the top to push it out the bottom.
A few weeks later it's time to reassemble and discovered that one piston is a 'loose' fit on one fork (i.e. fit the piston/washer/circlip to rod and can insert from the bottom easily) and is a rather tight fit in the other fork (goes in with some gentle hammer persuasion) -- and other piston is nearly 1mm larger in diameter and will need a hell of a lot of encouragement to go in.
As it turns out one of the pistons has a crack so I've ordered 2 new ones from Wolfgang (don't have access to a lathe or I might have turned a couple here) and while I wait for them thought I'd ask for some advice.
Clearly I have a difference in fork internal diameter -- not sure if this is common due to manufacturing issues or perhaps one of mine is out of round (not obvious looking at it) but just how tight a fit is the damper piston meant to be ????
Thanks
Andy
Thanks
Andy
