Gravelroad said:I'd suppose it's about the triple shown in your avatar pic?
Well, I don't have adjustable valves, but for changing the fork oil I just undo the 4 M8 nuts holding the bar clamp, then I move the entire boondoggle of instruments and handlebar slightly forward to the headlight and fix it in that position by a rubber bung or a bit of tape. That gives enough space to access the caps.
Regards,
Stefan
Reggie3cl said:Those are the pinch bolts. The ones to remove the instrument mount/bar clamp are under the yoke - 4 x 13mm nuts IIRC.
