How to remove the clutch basket from an Atlas?
Nick
Hi,
Anyone tell me how to do this without an special Laverda tools.
I have a broken return spring and it doesn't seem possible to remove the gearchange shaft without taking the drum off - if this is possible then again if someone can tell me how to do this then that saves taking the clutch drum off.
Thanks
Nick :-)
Hi Nick,
I did this many years ago without removing the clutch.
If I remember correctly, I modified the washer a bit with the Dremel to get it passing the clutch.
