Hydraulic clutch freeplay
OK starting from the top, how do I check my balls without taking the clutch apart as well? Maybe a magnet on the end rod to drag them all out through the right side?
Will double check the master cylinder but I'm pretty sure it's OK, I had it all lubed up when I fixed the lever not returning out problem a while ago.
Clem, pretty sure it's not losing fluid, the level hasn't dropped at all.
Piet, yes I must apologise, it's not really freeplay, there's only a mm or so real freeplay then it is depressing the master cylinder piston straight away but doesn't disengage the clutch till it's a long way in ie an inch off the handle bars. So yes the MC piston is returning all the way out.
Not sure what the slave o-ring is made of, whatever Wolfgang supplies as it's from him.
I'll see what getting a bleed nipple and flushing it out does first, may as well fix broken things first.
well - one you can see when you take of the right hand cover and look into the slave piston. is it still moving or is it not?
the other one you can pull out with a magnet on a stick, something like this:
get them checked, that is much more fun...  :D
wife, shouting from the kitchen: "Darling - how would you like your eggs for breakfast, please?"
Husband, answering from the bedroom: "sucked, licked and cherished, if possible, please..."
:LOL:
