mauricejota7604 Hero member Location Victoria Australia May 23, 2011 #1 Is the hydraulic slave cylinder O ring section 3mm?? in a 30mm cylinder? Thanks, M.
Golgother Hero member May 23, 2011 #2 Hey Mauricejota Aha a technical question I can almost answer .......... Not sure about the section. What I do know is that there are two diameters available 30 & 31mm and if you fit the 30mm to a 31mm casing the clutch will not work....... : I am told the later bikes had 31mm to make the clutch lever action easier. Cheers Matt
mauricejota7604 Hero member Location Victoria Australia May 23, 2011 #3 Thanks Matt I know about the diameters just not sure if the section is 3mm or 2.5mm?? M.
a14rgs Hero member Location Wiltshire, UK May 23, 2011 #4 Hi Maurice, Info I have states 3mm section. HTH, Alan
