I would like to borrow a Flywheel puller............
You're welcome to borrow mine, if you promise to send it back and pay the postage.....and don't ask me how much the postage is :-)
Matlock, Derbyshire
Whatever.
With all respect I don't think they are particularly expensive and you can get them from Slaters well worth having if you like to work on your own bike .
Regards
Tetley
Have you got the jesus nut undone?
Laverdaton said:
As title really, I would like to borrow a flywheel puller for my 3CL.
Can anybody assist me. I live in Gloucester
Thanks, Andy
I have organised to borrow one now
I didn't know that I could buy it from Slaters.........there about 45min from me, perhaps I need to take a trip there.
I know I'm going to regret this....but, ......what is the Jesus nut?.
(If it's the LH threaded nut..I've undone that) :D
It's those nuts that cause you to mutter "Jesus, that's done up tight!!" through your teeth, before you slip off and skin your knuckles!! :D  One at each end of the crank.... and a third behind the alternator on a MkI 180 (if you're lucky....  They're loose quite often, buggers the starter clutch if left unattended!)
A rattle gun is quite handy for these things.
Wot he said. I'm fitting a DMC to my bitza at the moment, and I tried to undo the LHT nut with an axle stand, a three foot breaker bar and a three foot bar locking the crank (with the end sitting on the axle stand).
A friend and I proceeded to lift the bike off the ground. The nut didn't move. JESUS!
Three seconds with a 20 quid rattle gun and it was undone. The best value for money of any tool that I have so far bought.
Chris
I agree that a rattle gun is an essential piece of kit although I have heard some old sages profer the opinion that they can actually rattle a crank out of line. Seems fanciful to me but I stand to be corrected?  I haven't worked out a way of dismantling a set forks without one!
Interesting theory, but I can't really see how it would work in practice - there's too much intertia in the crank. My crank didn't even turn while the nut undid. (Is that even a word?) but I guess locking the same end of the crank you are undoing the nut on while you rattle away would be a good precaution.
Chris
