chrissoz
- Sydney, Australia
On my 750SF1 recently replaced points with Sachse ignition. All went well and the bike is running much better. However...
... I have noticed a couple of times when putting the ignition key in but not touching any other controls there is a bit of noise from the engine, sounds like I have just tapped the starter button. Yesterday when I put the key in there was a puff of smoke from the carbs!
I was scratching my head about theses two rather odd occurences when it came to me - I popped a plug cap off, put the key in and Lo and behold there was a single spark after about 3 sec. What I think is happpening is that during the boot up of the electronic ignition it is producing a spark which is causing the small amount of unburnt fuel in the chamber to ignite, if the inlet valve is open this produces a puff of smoke, if not then it moves the engine a bit causing a bit of noise from the starter clutch.
Is this expected? I wired the +ve side of the ignition to the indicator fuse (as the bike has no indicators and it was a much shorter run than connecting it to the +ve supply for the coils), could this be the cause.
