beauchemin
- Victoria, British Columbia
Please have a look at the horn bracket. Is it the correct factory bracket? What do the horn mounts look like?
lemonjelly said:your having probs with no pics!
beauchemin said:The last set of Voxbells (reproduction, mind you) that I bought from Wolfgang did not come with the brackets.
Paul LeClair said:Hi Chris
looked at the original post photos and went whew...... I see an engine still in the frame, a front end still on, and no sandblasting done as yet..... I haven't gotten back to dealing with head stock frame bracing details yet, I may have to attempt to delegate that project to you, if you can dig up specs, and then MotoV can make the bearing recess plugs and CAD the pieces required for laser cutting....
for the horns, you have to have those multi ply mounting springy thingys, I have tried hard mounting the horn on a Laverda, it does not work, at least not for very long.... Wolfgang has them.
Paul LeClair
Paul LeClair
