L
lemonjelly
Guest
White nylocs
whats the world coming to?,will go with Cosis boots I suppose.
lemonjelly said:White nylocswhats the world coming to?,will go with Cosis boots I suppose.
jotajoe said:Did say Nylocs Shaun and not " Nylons" . A man should never be seen with white nylons, just ain't right
joe
Bunyip1 said:Be careful what you put next to your nuts.
http://www.boltscience.com/pages/helicalspringwashers.htm
nealebms said:Well all the 24" and 18" cooling water and fire main pipes in the channel tunnel should be lying on the floor by now then,as all the slider clamps and support brackets were put together with spring washers 20 years ago.Also the winding head gear at the Kent coal fields were built using spring washers and they stood for 80 odd years before being cut down for scrap,so maybe no need to worry too much
Neale
henry said:rats, i've just replaced all the m6 bolts on the sump of my 1200 trophy with ss bolts and these washers. does this mean i should take them off. the original bolts had nothing, but half of them nearly were awol so i thought the washers would help. is there an effective alternative??
