jet size 500 Alpino
Hi Maurice,
Standard Alpino 115 main  ,55 pilot
Have  you standard cams or are you running Monty S1 cams?
With std cams I'd go with main 125 , S1 cams try starting 140.Both on the side of richness!
Make changes and then pop along to nearest dyno  for fuel check.Take some jets with you to make changes ,if needed ,after runs.
I would leave the pilot jets alone ,unless you find when setting the mixture you are turning the mixture skrew more than 2.25 turns out.
If so increase the pilots to say 58.
Andy
