Jota - Clutch end float
PeteK
Milton Keynes
Just had the primary side to bits on my 78 Jota to change the chains and noticed that the clutch has a little float on the shaft, visible between the circlip and the sim washer.. is this normal to help chain alignment or do I have a shim missing?
Depends which bit, if you're talking about the inner basket, check your main shaft is not loose in the bearing, or the bearing in the case.  A knackered inner basket circlip can also pop out of the groove - all of your spring pressure is against it when the clutch is pulled.  In that case the whole shaft or clutch assembly can move in and out, can happen.
The outer basket sits between a washer on the step in the shaft, and other washers behind the circlip on the outside.  It is meant to have a little clearance since it needs to spin on the shaft when the clutch is in, but not much.  No doubt there is an official clearance specified somewhere.  The washers allow for alignment with the front sprocket but if they've been mixed up or omitted you can end up with too much float on the outer basket and/or alignment issues.
HTH
SteveB
Usually a shim washer also on the inside of the clutch drum.
Put a flat edge from the crank sprocket to the outside edge of the clutch drum and shim the clutch drum until they line up.
From the factory workshop manual, page 53:
"Make sure that the side clearance of the clutch drum (one-piece construction with driven sprocket) is 0.10 ? 0.25mm.  If required, add shim to obtain the specified clearance."
Tom
