mcnicol
- Safety Harbor, Florida, USA
Has anyone who's done this kept a record of how long they had to have custom front brake hoses made? Specifically, I'm looking for the length I need for my '78 Jota (with Jota bars) and reversed forks (calipers behind the sliders, although I don't think it makes any difference to the length, I'm using the standard hoses already). I'd like to eliminate the splitter and have 2 hoses running straight from the master cylinder to the calipers, mostly to make to system easier to bleed. I don't want to have to disconnect my existing system because I've finally got all the air out of it and I don't want to have to start THAT process again.
I know I'll need a longer banjo bolt for the master cylinder, with a switch built into it (until I try a different master cylinder with a mechanical switch). Ideally, if there's a packaged kit I can buy for another bike from Venhill etc I'd rather do that. The custom hose makers I've run across here so far can best be described as dodgy (or worse)
Ken
Ken
