ngiles
- Sydney, Australia
In readiness for club registration I checked the lights etc and find the front brake switch is not working. Rear one is working and if I circumvent the front hydraulic switch by putting a wire across the two connectors then the brake light can be made to turn on, so the problem is with the switch not activating. Not familiar with it but some questions:
- To remove switch - does that require the brake fluid to be drained and then re-bled as I assume once the switch is unscrewed fluid will dribble out of the hole
- Is the switch serviceable or is it likely that I will need to buy a new one - if the latter I see the one in the image attached offered by a place in the UK - but does anyone know of a local supplier of a replacement switch?
Thanks, Nick
Thanks, Nick
