jdugen
- Manchester UK
(Must be one of the longest titles?)
Anyway. Trying to get to the bottom of my high(er) speed wander. Perfect up to 90, weaves set in above. New front tyre fitted, back looks to be fine (but am beginning to suspect it). Stripped out the swinger to take a good look at bearings etc, and noticed the paint worn through to bare metal around the inner linkage of the back brake.
With the coil return spring fitted, the lever part that goes through the frame juts into the swingarm space. Spring removed and the lever pushed much further into the frame giving good clearance.
At the moment I have made up an alternative coil spring attached to the linkage on the footrest side that works and looks neat enough. Anyone else come across this 'little foible' or do I just shrug and get on with my life?
