ngiles
- Sydney, Australia
I put new roller bearings in the swing arm of the Jota today. Each one had a washer inserted prior - as shown in the parts manual. However the washers I received were shaped to be concave on one side, convex on the other. Whilst the parts manual describes a 24 x 32 x 1 washer these were clearly wider than the 1mm specified due to the shape, and so led to the bearing cages protruding a little. So I took it all apart and am rethinking. Couple of questions:
- Anyone had the same issue?
- When I took it all apart there were no washers on the inside of the roller bearing cage! So I wonder whether to leave them out - any thoughts?
- Anyone know where to get a flat 24 x 32 x 1mm washer?
Cheers, Nick
Cheers, Nick
