Key cutting
TStanb
Hello
The ignition key says
Silca
Italy
and YH28 (in a little circle).
Where/how can I get a couple of copies
Any competent locksmith will be able to supply & cut blanks. Same key used by Suzuki & Yamaha, ilco YH28/X67 key blank is an option.
If you have a problem finding a key cutting service that has the right blanks as I have in the past for older Italian bikes, there is a company called Basildon locksmiths,  Orion Court, Basildon. That can supply most keys using the key number
If it's the original key it should have a 3-digit number stamped across on the top.
I've found my key# as a cheap Suzuki key replacement on fleabay.
HTH
Gerald
TStanb said:
1980 180 Series 1 triple
... if you have problems to find the right key blank, you can order here also:
http://www.motalia.net/product_info.php?products_id=2390
But you'll need the three digit number.
Ciao, Gert
Also here-
https://www.ebay.co.uk/itm/Suzuki-key-cut-to-code-number-Kawasaki-Laverda-motorbike-ignition-key/274179558657?hash=item3fd6600d01:g:nYsAAOSwZrtasSBp
Keys in the post sorted me in double quick time for ?11.00, without wanting to know the make, model or barrel number. Just two photos by email with the make of the key (Silca).
Great service.
