Laverda 500 Loom
SeeDoubleYou
Just a quick one, I've just been out to start connecting up the Loom on my 500. It's a bit of a mess but pretty much all there. Can I just ask though, the loom looks about a foot too long and is folded back and stuffed under the tank. Is that usual?
The loom is essentially identical to a 180 BTZ triple loom.
Maybe you have a triple one, which from memory I think is a bit longer.
I fitted a triple loom to a 500 once, recall having to shorten some wires in the sidepanel area.
Both bikes are effectively 180 twins, as the triple has 1 and 3 sparking as one.
The one on my Mk1 is folded over and attached to the downtube between the carbs.
On the Alpino the ignition boxes were behind the side panel, I just assumed the re-site left some extra bits left over.
Maybe worth having a look at this http://rupesrewires.com/laverda-montjuic-mk-2/#prettyPhoto
