Laverda 60cc miniscooter clutch
wroe22
US
Anyone know why the clutch on an old 60cc Laverda miniscooter  will only engage at very low idle? Clutch seems to still have pad life left. Just wont engage.
I had the same sort of problem on my Miniscooter. There is a fiber washer inside the clutch drum that acts like a sort of damper. I found out that the thickness of this washer is critical, only some wear is sufficient to cause clutch slipping or dragging. My washer was broken and I decided to replace it with an aluminium washer with the supposed same thickness. Didn't work at all, clutch dragging. It was only after playing a lot with some fiber material, cutting new washers of various thikness that I finally got the clutch running.
