'71 SF said:Red, I was thinking about doing this to my newest project, but does the weight reduction and pin size change increase the horsepower enough to offset the cost of doing it. In my post on "hypothetically speaking" I was trying to get ideas on a caf? build with a little engine change to give it some additional attitude. Scott has the engine now and before he starts the rebuild I want to figure out how radical to go.
Clay
Red loctite.ludiluka said:Redax5 Is it possible to get cnc program?
This will be my first crankshaft mod and i am terrifiedso 35mm pin (if i understan correctly this is pin that conrod connect to?) So i need new conrods. What is the best choice? I will get pistones cams valves from Brettoni.
What loctite are you using?
ludiluka said:Augusto Brettoni told me that he was always racing with stock crankshaft ?? I don't know what to do now
Worn out?Need help again. Can somebody measure dimension on photo. I’m not sure if my part is worn out or not. Also does anybody have this part for sale
Somehow gears got destroyed during riding. after dissasembly there was a lot of metal mixed with grease,... i just want to check that everything is ok before installing new gears. bottom bushing in wheel cover is for sure worn. Shaft diameter is 5,45mm and hole in bronze bushing is almost 6mm.Worn out?
