Laverda Ghost/650 gear spline - Is it the same as an Alpino gear shift spline?
Jeremy Wilton
Cropredy
Is the gear change spline for a Montjuic/Alpino the same diameter and spline pattern as that for a Laverder Ghost/650 - I need to make up some rear sets for my 500 speziale and these might fit?
Jezr
Thanks mate - I have that piece attached at the mo and reversed so it's all upside down. As I don't yet have the sito pipes onit , there's no room for the gear change pedal - once Coxy has made up the pipes (apparently they're near completion) I will be able to sort out a linkage... I just saw a set of Ghost linkages on fleabay and thought they'd be a good start...cheers for now
Just something for you to consider
I am just removing the long linkage set up and have found an Alpino lever which I am going to fit this weekend upside down, this is to give me a more positive feel (hopefully) and to eliminate the long linkage which can foul things and in certain positions will stop my feet getting at my lever when I need to, its also a pain in the arse to adjust correctly, this is on my Monty race bike
I will know more by Sunday night, I am testing at Mallory on Wednesday, if it works that will be the place to find out - I will let you know
