Laverda Ghost 650 Strike
Just aquired one of the above bikes (1997 or 1998 model) with only 1200km on the clock. However, I fitted a new battery but the ignition light does not extinguish after the bike starts. The right-hand red light (oil pressure) does go out, but the left-hand red one remains on. Any ideas what the issue can be? Where can I get hold of a wiring diagram for this bike?
Hi
It sounds as thought the regulator/recitfier is kapput - have a look at my post on the subject as I have recently had the same problem with my triple. 1st thing to check it the voltage to the battery - should be 13.0 to 13.5v ish with the engine running. Then check all the connections before you spalsh out on a new RR.
http://www.laverdaforum.com/forum/index.php/topic,91455.0.html
I think the RR51 item is the correct one for your bike
http://www.electrexworld.co.uk/acatalog/RR51.html
Glen.
There's a heap of Ghost 650 parts on eBay at the moment, in the UK.
http://stores.ebay.com.au/TRAILBIKE-STORE/Laverda-Ghost-/_i.html?_fsub=5478694012&_sid=104371052&_trksid=p4634.c0.m322
Cheers.
A ghost 650 you say tick tick tick tick tick tick tick tick  (bang)    :D
              Dave
