CLEMTOG
hello Pierre, I would say too much fuel is getting in causing an unusually high compression pressure, so check the float valve tips and then the float heights, if that does not solve it, connect a car battery direct to earth (-) and then touch the plus (+) lead direct on to the brass terminal of the starter motor, if it turns normally then you have a wiringing or relay problem, if that fails get Marilyn to tow you everywhere on her 500!!!
