Leaking tank
chrisk
Anyone with one of Boba's carbon tanks with a Mona filler had a leak?
I do, but can't tell from where it's leaking from, the cap proper or from the base of the filler.
FIX IT with Lepage's 24 hour Metal Epoxy Glue and re-tap the threads using Green Teflon Tape if you are referring the to Pet Cocks. The Gas Tank Cap always have a tendency to splash weep, then play with rubber gaskets.
