Looking for a early LAVERDA 1000 3C tank and left side engine cover with 1000 script.
I will stick my neck out, I think the tank is correct. The right hand petcock outlet should be slightly forward of the left hand one. Later models, the taps are in-line. Given the price, it would be worth checking that detail with the seller.
A seller on eBay has an early primary cover without the dimple for the chain adjuster for sale. A Quick Look under Laverda parts should find it. Good luck😊👍
Tom
both of those parts are realy quite rare, the drummer tank with differing underside due to the lack of crossover carb linkage and offset taps and the primary case WITHOUT chain tensioner axle dimple. if you find them in any condition BUY THEM, you might get a second chance!
