Lowering bike
Eddie
I bought a Kouba(not sure on spelling) Link from the US for my wife's ktm. They make a variety of lowering links for bikes.
If you want you can drop over and compare the measurements between the ktm OEM and the Kouba link. It dropped it about 30mm. I also happen to have a bare 668 frame on the bench fitted with the rear suspension that you can measure and compare against if you wish.
We should be home most of the Christmas period.
Regards, Greg
Before you get medieval with your seat make sure that cutting it down will really help as the width is often the bigger problem 'cos it spreads your legs. Cutting out the foam can exacerbate this leg spread effect. Either way good luck.
