Clem,
according to my discussions with Piero Laverda, there was just one prototype built by Uwe Witt (basically an RGS Corsa with re-painted frame, a single seat shaped similar to the later production run with 2 seats, an altered RGS tank and with kind of "Jota style" rear sets) and one by the factory. The one built by the factory was sent around Europe for Promotion of the production run, it was the one with the colored instruments. Also, the 16" frontwheel was only on these 2 from factory side, as road tests showed significant issues with the combination and they went back to 18" on the front, too.
Don't know where these rumors always come from, but have you heared of one stating there was a V6 in Spain left behind from Laverda after a significant engine failure? Pure bullshit... No factory would left behind a prototype of a bike they want to use as a test-laboratory. How should they get results if they could not examin what actually failed?!?
Laverda typically only built one or two Prototypes, not series of (and for sure not 5 or 6...). That is only logically, as a) trade-shows where they present such a prototype are normally not all at the same week/weekend. There is time enough to send the bike around. Second point is, that if you use the bike for testrides, it makes more sense to use the SAME bike for testrides, as only that way you get comparable results.
So - to my best knowledge and according to Piero Laverdas e-mails to me, there was only 1 factory prototype for the 1000 SFC.
