Hello I wonder if anyone can help me with a problem? I've managed to get my RGS running at last, but there's a little problem that makes it potentialy dangerous. She fires up ok on full choke, reducing to half choke virtually straight away. Then almost closed after a couple of minutes, I'm still trying to sort the idle speed. at present the mixture screws are one and a half turns out. But a gentle blip of the throttle results on the revs rising too around 4000 rpm a staying there for a few seconds after the throttle has been closed. This has never happened before, I think it might be the carb float height. I've tried as near as possible to get 18.5mm when there're closed. Does the fully open height have any effect on running? If so can you tell me what it should be. I've read lots of the carb float posts, but none with the same problem.
Pulling the plugs, she's not running rich, ok infact. I'm about to have the carbs off again to renew some "o" rings. Any help would be gratefully received.
