There is an improved amount of dampning, I am however biased to the benefit as i run the lovely Brevatto bars - clocks go on, clocks go off, bars go on bars go off.
Open laundry time: I was chasing a handling issue, which i was attributing to the front end, however it transpired that my flash new Wilburs were issued with a too soft spring, by the time that realisation had landed the emulators and been in and out a 'few' times. In addition to the painful aspect the preload on the spring kit was 8mm out not nearly enough sag. I think i am on for one final adjustment on the front - just need my right thumbs extensor tendon to do a little more knitting and loose the cast and i'm back into it.
For the Scottish hooligan that you are, get em- its an improvement.
Peter
