OneThinBloke
- Oxfordshire, UK
Finally got 120 Jota fettled and running sweetly
So did a short test ride before booking an MoT. A small amount of clutch slip but otherwise all hunkdory. MoT booked at my nearest available test station, and off I toddled.
The clutch slip became worse and worse, but stringent MoT passed all the same. By the time I arrived home the clutch slip was quite extreme and bike almost unrideable
I've stripped it down:- Steel plates had become very hot! see pics.
Friction plates measure between 2.9 - 3.3mm
Springs all in the range 46.5 - 47.3mm
There are also 3mm washers which would lighten the spring loading but by enough to cause my issues?
I had installed new push rods and ball bearing, supplied by Slaters.
Thoughts and solutions welcome
