maxton
been looking for somewhere to post this. it's just for general interest, but maybe it's in the wrong section :-\
it's an answer to an enquiry - 38mm Marzocchis:
Thanks for your enquiry, we can help you out with the problem on your forks but have no spec sheet for you to read.  We convert your forks, but not by modifying the existing internals.  We throw everything inside the fork away and start again with our internals.
The internals we supply is our own GP20 cartridge style damping system. The cartridge system is the same type of internal as what you would find in any modern front fork.  It has been manufactured and developed by our own engineers and has pistons and shim stacks for the rebound and compression damping.  The Cartridge also has needle valves so you can adjust the damping.  The damping adjusters are external, so you can change the damping without having to strip the forks down, but we hide the adjusters to keep the classic appearance.  As part of the conversion we also machine new fork tops to take the new cartridges and damping adjusters.  We also fit new springs.
Every Maxton GP20 cartridge is built to order, the reason for this is to valve and spring the cartridges to suit the fork, the bike, the riders weight and what they are using the bike for.  Once the cartridge has been manufactured we then fit the cartridge to the fork to make sure it works correctly.  In most conversions we have to modify the original bottom sliders and stanchions so our cartridge will fit and work properly.  The forks are then returned to you fully serviced with new seals and the spring preload and damping set up.
The Maxton GP20 cartridge costs between ?295.00 and ?495.00 + V.A.T.
Depending on how adjustable you want the cartridge to be.  For ?295.00 + V.A.T the cartridge is adjustable for rebound damping.  For ?495.00 + V.A.T the cartridge is adjustable for rebound and compression damping.  All adjustment can be made without having to strip the forks down.
To service the forks with new seals and install the cartridges costs ?125.00
+ V.A.T.  In some cases there are also charges for any extra work to get
+ the
forks to work correctly.  In Norton and Seeley conversions we machine new bushes for both top and bottom sliders, the bushes are made from a hard wearing frictionless plastic called Delrin.  The bushes cost an extra ?80.00
+ V.A.T.  In some cases we also have to get the original sliders honed
+ as
the bore of the slider is not machined very well.  The cost of honing the sliders is ?80.00 + V.A.T for the pair.  In some Triumph forks the seal is held in place with friction on the outside diameter.  We machine a groove in the bottom slider, so the seal is retained with a cir-clip.  This costs an extra ?50.00 + V.A.T.
The cartridge conversion fits inside most forks with stanchions that have an outside diameter of 35mm or bigger.  In some Honda forks the stanchions are 35mm outside diameter, but the internal diameter of the stanchion is too small for the cartridge to work.  For these forks we supply new Hard Chromed stanchions with a larger internal diameter.  These cost ?200.00 + V.A.T a pair.
If you need any more information about the modification we carry out you can ring me on the telephone number above, if you cannot get through fax me your number and I'll ring you back as our phone can be very busy.
IF YOU LIVE IN A COUNTRY WITHIN THE E.E.C THEN YOU WILL HAVE TO PAY U.K V.A.T, UNLESS YOU HAVE A TAX CODE FOR YOUR COUNTRY.
Regards
Maxton Engineering
Henry,
as you are in southern Germany (or was it switzerland?!?), you could also consider www.hh-racetech.de. Mr. Hoffmann is a known Guru for suspension, not to far away from you. You could bring in the legs, talk everything through with him and and even collect the items 2 weeks after. He builds to your specs, too. You can even bring the hole bike and he will do the setup for you, too, at minimal extra costs. I will send the legs of my Jota and 1000SFC shortly to him, as some Austrian Laverdisti stated they are more than happy with the fork-conversion he did for them.
A full cartridge conversion (even including sping-preload from top) is roughly 700? including VAT for a fork (both legs). Considering the high shipping costs to England and back as well as the short distance you could travel to within an hour or two if something does not suit you would make me consider him. Up to you, however.
best regards
Lothar
