Reggie yep I will do a write up one day as have tried to keep some documents.. just getting the time to sit down and do it and will be most likely after I do the 33's or have the operation on my friendly gall bladder and then are bed ridden.Piranha Brother 2 said:Hey Brett, are you sure they're downdraft? Umm Yep am sure They are usually fitted to Yamaha FZrs and R1s. Horizontal are a la Suzuki GSXR and what suit the Lavs. You think
Do your FCRs have choke systems? 39's do 35's dont or do you start using the accelerator pump method? on the 35's yep I do, no biggy Interested because I'm fitting 2 pairs of 39mm FCRs to my two SF-based motors and have faith that with no chokes, I can start with a couple of pump squirts (as brother Tippie has always done successfully on his).
Quentin
mauricejota7604 said:Hey Dave never heard of that one before I am planning to put a pair of 41mm Keihin Flat slides onto my 1100 Sport Guzzi as the results are amazing!!!
Brett said:Reggie yep I will do a write up one day as have tried to keep some documents..
