- Calgary, Alberta, Canada
Hi all
I am fiddling with the RS 36's from the RGS, trying to lean them out and still run well.
float height - no issues setting the height correctly and the same for all three, but, has anyone thought about what setting the float limiter tab should be set for? The float height tab obviously adjusts the height at which the float valves start to close. But, the other tiny little tab sets how far the floats are allowed to drop. Presently I have themm set so the floats can not drop all the way to the bottom of the bowl if the bowl empties, as I don't want the float needle valve to be able to come out so far that they could jam, but is there a specific setting recomended?
accelerator pump setting - at what perecentage of throttle opening is the beginning of accelerator pump actuation recomended to be set for? I have tried everything from just off idle to half throttle - the pump gives a pretty big shot of raw fuel - at the moment I have set it back to coming in at about half throttle
needle for a 120 - there are two basic needles available for the RS 36's, and I have tried both. The richer of the two needles seems too rich no matter what notch I set the clip on. The leaner of the two needles is still too rich my my RGS "1200" motor with the clip at the third notch, and I am about to try it witht eh clip at second notch from the top.
Who else out there is running RS 36's on a 120 motor? What settings are you using?
igntion timing - WITT on a 120 with high comp pistons - what curves are in regular use? I am back to the basic setting 2 which is most like the original Laverda setup, goes to a full advance of 32 degrees BTDC at around 2,750 or so, that's it. With todays fuels I am wondering if even 32 degrees may be too much advance and I am thinking about retarding the ignition back 3 or 4 degrees to maybe 29 or 28 degrees - thoughts, recomendations?
Paul LeClair
Paul LeClair
