Cam,
One of the best features of the Mikuni Flatslides is their ability to let the engine idle, even the big bore high comp engines we build will happily idle below 500 rpm if we wish to drop the adjustment down. My 2nd Jota, 1175cc with the works will idle at < 400 rpm (digital tacho). There must be something amiss if you are experiencing issues at idle.
Power figures are no surprise, carbs by themselves cannot really make an engine produce more power but the carbs can and will change how the engine performs through the rev range and that is what Piet refers to with the rideability comment, totally agree.
Lothar, our Dyno has a built in weather station, it constantly measure air temperature and humidity and from those measurements the Stuska software calculates a correction factor. As the engine runs the HP is calculated by the software using this correction factor, engine speed and the readings being sent from the strain gauge on the Water Brake itself which is basically measuring deflection.
To do the initial set up on the Water Brake you bolt on an arm of a known length and then add "x" lbs to the end of the arm which causes the strain gauge to measure a deflection, you then set a calibration point in the software, add higher weights, calibrate, etc.
Any computer controlled Dyno would be operating in a very similar manner.
Red
