Mikuni RS36 checking for blocked pilot jets
Rob
Midlands, UK
Can anyone explain how to positively check for a blocked pilot jet / drilling?  One of the bank of three doesn't respond to alterations to the pilot mixture air screw and I've done the usual squirting of carb cleaner / airline on all three to find no difference between them.  The air screw has its tapered tip intact.  Just wondering if I've missed something.  The Dellorto check below is pretty straightforward and I wondered if there is something similar for the Miks?
The easy way to check the progression galleries with carbs built and on the bike is -----remove pilot jets and mixture screws-----open throttle----use a can of carb cleaner with extension tube fitted -------put the tube up the hole where the pilot jet goes  cover the mixture screw hole with finger and squirt cleaner while looking for a stream coming up into the venturi. just in front of the back edge of te slide.
Then put the tube in the mixture screw hole cover the pilot jet hole with finger and squirt cleaner whilst looking for a stream coming out between the slide and the engine.
Then put the tube into the little air hole  under the  carb intake (not the "middle" one----the other drilling)----squirt  and look for cleaner in venturi.
Hi Rob, need to be real careful with the pilot screw, if turned in too tight the tip has a habit of breaking off!! Can be a pain getting it out.
Had the same issue with my mikunis, no response adjusting the pilot.
Rob
Hiya Rob - yep, had read Red's build/fitting guide with warning about that problem on used carbs.  These are new and def don't have that issue
