merlin
- gunnislake cornwall
had the air filter apart today and someone has cut down and fitted a car type filter is this OK ,if not what do the experts recommend to fit
dave
dave
someone
Laverda SF said:someone
Hate that "TERM" - If you're a Motorcyclist's and determined to "OWN" a Ride, you have committed to learn every nut an bolt that makes up that ride and mold her for your personal satisfaction.
"Someone did this - Someone did that - F*%K it - Do what you want to do."
merlin said:the bike has the original air box with a car paper element cut to fit inside I thought this may be a bit restrictive hence the question
dave
if you still have the original filter holder then most of us split it apart and use air conditioner gauze element
buy a small roll of it, cheap as from any air con repair place, cut to size, insert in original holder, works very well
if you don't have the holder then you may have to get a Uni-filter but wash and dry it well before use, you have to remove the oil or you get a 5,000 rpm rev limiter
Disappointing answer, 'Laverda SF'.
It was a genuine request looking for intelligent advice...
well thanks for 2 very informative answers it has helped me make my mind up, as I have only owned it for 3 months I am still learning about laverdas but I think I will cut my losses and once I have sorted it I will sell the bike
dave
