Mk3 Motodd engine mounting
Hi Andre, eliminating those spacers is probably a good idea as they do wear on the mating ends. While my motor is out, that lower rear bracket is one of the areas I'll be looking at doing some mods on as mine has also cracked again on the L/H side, which is the side with the longest spacer.
Rob - my lhs spacer is the shorter one, rhs is longer. And yes there is wear at the mating surfaces. I suspect the spacers were there to provide 'individual' spacers to suit individual frames. Takes up manufacturing variances huh
