M
morison
Guest
Ian ,
I don't understand why you would want to set it back to the standard pre load. Isn't this irrelevant. Don't you need to set the preload to suit your rider and the current weight of the bike in race form?
If your getting chatter and you're running valves don't you need to play with the oil viscosity? This is the controlling factor for rebound dampening. Maybe you need to play with the tyre pressures as well.
These 500's weigh bugger all, so how hard is it to get one handling properly?
Chris
Chris
