Monty Tires
Gbarnes3
Have just pulled my Montjuic wheels apart for powder coating hence will need new tires! what's the latest and greatest tires being used on Std fitment wheels.
And while I am writing does anyone know if the wheels can be used for tubeless tires.
Glenn
Hi Glenn
I'm running Pirelli Sport Demons on one bike and Bridgestone BT45 on another. Like both, will spend $on Pirellis next time.
Jason
I have been running my 500 Zeta tubeless for about 18 years. You have to work out getting a schrader valve installed.
Art
Glenn,
The Laverda cast wheels were designed to run with tubes for a reason. The factory felt that they couldn't guarantee the non porosity of the cast rims and were wary of creating a problem for themselves. I've heard a number of Laverda riders say they run tubeless with no problem but from my point of view I think motorcycling is dangerous enough without adding unknown variables into the equation. The risk versus reward doesn't stack up for me.
Ready to be shot down once again, but I do agree with Bob.
The rims were NOT designed to be run tubeless.  Tubeless rims have a different design on the inside of the rim, has something to do with retaining the tyre once the air escapes... only reason tyres remain on the Lav rims is they were incorrectly designed in the first place.  A royal pain in the arse removing old, stubborn tyres, much more so than with any other contempory rims.  Even fitting new tyres with a not-so-pliable sidewall can turn into a nightmare.  Get a very queasy feeling inflating a tyre to 7bar/98psi trying to get the bead to seat properly!
The factory chose to fit tubes at a time when tubeless tyres were just beginning to appear.  Perhaps they didn't trust the new technology or simply ignored the advantages, take your pick.  Porosity issues could have been solved by coating the rims at manufacture.
Keith has machined Laverda rims to dimensions that allow easy tyre fitting and removal, perhaps the tubeless type rim profile can be incorporated and allow tubeless tyres to be fitted with a quiet conscience.
